Re: Farmall 806 with DT436???
Posted by karl f on December 13, 2009 at 17:55:07 from (172.164.210.43):
In Reply to: Farmall 806 with DT436??? posted by Little Acres Austin P on December 12, 2009 at 20:15:39:
easiest swap is the 407, if the 806 was a diesel.
361 and 407 engines are getting spendy from what i hear.
Lots of people have done the newer engine swaps. It's doable but it depends how much time you want to put into it.
hope someone with good instructions pipes in.
karl f
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
