It is not necessary to split unless the Flywheel is to be removed. There is high probability that the clutch cover has 3 release holes in it. these are bolt holes that have nothing in them at each lever pivot point. The clutch cover bolts (6) fit these holes. Remove every other cover bolt, and screw them into the open holes. This compresses the springs allowing greater freedom of movement of the shaft. The shaft does certainly come out, holding your mouth just right helps. Take pictures, and put the coupling together the same way it came apart or serious noise will result. JimN
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
