Re: Farmall 806 with DT436???
Posted by mkirsch on December 14, 2009 at 05:14:10 from (64.80.108.57):
In Reply to: Farmall 806 with DT436??? posted by Little Acres Austin P on December 12, 2009 at 20:15:39:
If you use a 66 series front engine plate, rear engine plate, and frame rails, the whole assembly will bolt right up to the 806's bell housing.
You'll need spacers to bolt the front bolster back in place because the 66 series frame rails are spaced farther apart.
This may make the tractor longer, so the hood and hydraulic lines may not fit.
You'll also have the challenge of getting the throttle and radiator hoses connected and functioning properly.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
