Re: Replacing a Clutch in a M and need HELP
Posted by billde on December 14, 2009 at 15:45:14 from (72.26.89.156):
In Reply to: Replacing a Clutch in a M and need HELP posted by IHDairy on December 13, 2009 at 18:19:28:
Haas said: (quoted from post at 07:46:19 12/14/09) I've done this job and could not get the clutch out untill I removed the clutch release fork and the cross shaft that work the fork that moves the throwout bearing. You have to remove the clutch release sleeve (I think that is what it's called)bolts that hold the sleeve to the top of the housing. The cross shaft is held in place by the clutch fork. There are two bolts and two thick washers that act as keys to hold the fork to the shaft. Remove the bolts and the thick key washers plus all the external attachments to the cross shaft and the cross shaft will slide out. When you have all that out, compress the clutch springs like the others said by putting the three bolts in the clutch plate. Now you can tilt the drive shaft and it will come out. As I recall, I got mine out with out taking out the cross shaft, but could not work it around to get it back in until I removed the cross shaft. I have complete instructions that I wrote up some where in my archives. If you want a copy, send me an E mail and I will dig up the document.
I would like a copy of the instructions if you would please. My email address is in my profile.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
