Re: Fixing an Ah Schitt!
Posted by ScottyHOMEy on December 14, 2009 at 17:29:13 from (71.241.202.181):
In Reply to: Re: Fixing an Ah Schitt! posted by Roger46 on December 14, 2009 at 16:37:22:
My gray moment is gettin' darker (or is that lighter?) but is still somewhat gray. I think you're right, Roger, on the rear seal retainer, that perhaps the split cap on the back may thread into the retainer. But for the front (which isn't the one that is leaking but IS the one that is stripped out), I don't believe there's anything holding it to the crankcase except the two bolts that run up through the ends, so it may be possible to pry it out to be cleaned up and fixed on the bench.
