Re: O.T. CHEVY P/U 350 3500
Posted by Bob on December 14, 2009 at 18:29:52 from (69.178.228.68):
In Reply to: Re: O.T. CHEVY P/U 350 3500 posted by ericy on December 14, 2009 at 17:13:38:
Define "oil thingy"... did an oil cooler hose blow or did the oil cooler fail, or did an "o" ring or gasket fail on the adapter between the engine block and the oil filter?
Simply find out what's leaking and repair it. I wouldn't think any "rocket science"would be involved. Lines are readily available and gasket/"o" ring kits are available if that's where the leak is.
Also, if you choose the remove the cooler and lines and plug the holes in the adapter the oil cooler bypass valve will have to operate at all times since the flow path through the cooler has been eliminated.
