Posted by Chris NW Ind on December 15, 2009 at 02:53:11 from (64.136.26.230):
In Reply to: w9 camshaft change posted by gpa rick on December 14, 2009 at 16:58:03:
I did the very same job over a year ago. Pull the radiator, valve cover, pushrods, lifters, oil pan and pump. Unscrew the big nut on the pulley and tap it off from behind (tap as close to the crank as possible). Jack the engine up a tiny bit to remove the front mount and remove the front cover. Unbolt the front camshaft retainer thru the gear and carefully slide the camshaft and gear assembly out.
What is wrong with your camshaft? I suspect mine was slightly bent, creating a terrible knocking noise at valve #3.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity!
... [Read Article]
