Re: 766 starter relay
Posted by El Toro on December 15, 2009 at 04:14:57 from (74.103.74.58):
In Reply to: 766 starter relay posted by rz1t0x on December 15, 2009 at 03:17:14:
Have you loosen the starter bolts to make sure the bendix drive isn't stuck? You need to clean all the battery connections at the batteries and at the solenoid & the starter. Your solenoid may be the problem if no voltage is being fed to the starter. Use a volt meter and see if the starter is getting battery voltage when someone makes an attempt to start the engine. Keep your hands and fingers away from the starter drive & flywheel. Hal
