Re: 766 starter relay
Posted by IAGary on December 15, 2009 at 04:33:48 from (216.51.225.93):
In Reply to: 766 starter relay posted by rz1t0x on December 15, 2009 at 03:17:14:
Why would you not think the solenoid has gone out completly now?
If you have voltage from the solenoid to the starter then it could be the starter.
If the solenoid is not putting out voltage to the starter, it is the solenoid or the switch.
If you have no voltage on the small excite post of the solenoid when the switch is engaged then you have a switch problem.
Gary
