Re: 766 starter relay
Posted by Brownie 450 on December 15, 2009 at 05:19:48 from (66.43.241.141):
In Reply to: 766 starter relay posted by rz1t0x on December 15, 2009 at 03:17:14:
While the solenoid is energized, try shorting across the 2 large terminals [1 from the battery, & 1 to the starter] with a suitable tool. If the starter turns the engine, the contact at the back of the solenoid is probably bad, or one or both of the lugs aren't making good contact with the solenoid terminals[ happened on our 1066].
Of course, observe the usual safety procedures--tractor in neutral--wheels blocked--don't wear a tie--& so on. When shorting, try to short using the nuts--not the threads on the solenoid.
