Re: 3rd wheel weight on a SM-TA
Posted by mkirsch on December 15, 2009 at 05:22:47 from (64.80.108.57):
In Reply to: 3rd wheel weight on a SM-TA posted by RBTXS on December 14, 2009 at 17:30:25:
You're only supposed to use 2 of the holes around the edge of the weight to mount the 2nd weight. The 3rd weight is attached using the remaining two holes/slots.
I also believe you need to rotate the weight so that a hole in the outer weight lines up with a slot on the inner weight.
Or, you can take them all off and install four long threaded rods in the wheel, nut on both sides. Slide as many weights on as you like.
