Re: dont know what model I have for sure
Posted by mkirsch on December 15, 2009 at 09:30:47 from (64.80.108.57):
In Reply to: dont know what model I have for sure posted by TheDurk on December 14, 2009 at 17:29:55:
John Blasius said: (quoted from post at 08:38:35 12/15/09) The number on the seat bracket Is FAA 355221 and the number on the trans housing is 351687-r5
Okay, the number cast into the trans housing is the part number, not a 140 serial number.
The serial number under the seat indicates a very late 1954 Super A, just before the start of Super A-1 production (356001 is the first Super A-1 serial number).
Look for casting codes on the large parts, especially the engine. It should be as described earlier, in the format of XX-YY-A, month-day-year.
The year part of the date code should be a "Z" on all the cast parts. If the engine has a Z-code, then you have a Super A with 140 sheet metal.
