Re: H, SH, M, SM Parking Brake Lock Lever
Posted by GeneMO on December 15, 2009 at 09:50:58 from (205.201.122.82):
In Reply to: H, SH, M, SM Parking Brake Lock Lever posted by Red Mist on December 15, 2009 at 06:04:54:
My uncles were quite the inventors. They made a lever that worked a roller that set along the fronts of both brakes. IF, your brakes were both working properly and adjusted the same, you just pulled the lever back, it forced the roller foreward, then kinda went over center and both brakes were locked.
Another uncle has one they made for his tractor. I'll try to get a pic of it.
Gene
