Posted by Owen Aaland on December 15, 2009 at 10:51:20 from (65.165.246.148):
In Reply to: 766 starter relay posted by rz1t0x on December 15, 2009 at 03:17:14:
The starter/solenoid can be checked with a test light. Engage the solenoid. Use the test light on the terminal that goes into the started. If the test light lights up the problem is in the starter, most likely worn brushes. If the light shows no power with the solenoid engaged the problem is the solenoid contacts, usually the one where the battery cable attaches.
A bad connection in the solenoid can often be corrected by removing the battery cable and loosening the nut that holds the stud to the cap. Unscrew the nut enough to be able to push the stud in and turn it a half turn and them reassemble.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
