Like they said, alternate slots on the outside of the weights. That parts book where you found the P/N will also list the lengths of bolts you should use. IIRC the bolts that go to the cast center are about a half inch longer than the rest. On my pulling tractor I use AllThread/ReadyRod in two of the holes and then smooth bar on the other two holes for alignment. I DO NOT USE THIS IN THE FIELD (much ;)) I only do this bc you need to change weights quickly at the pull. This arangement will ALWAYS loosen up when doing field work no matter how tight you get the setup.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
