Posted by Dave H (MI) on December 15, 2009 at 18:23:11 from (64.12.116.73):
In Reply to: Aquired an H today posted by Tennessee Farmall on December 15, 2009 at 17:15:47:
Everyone has there own set of "what to do" on a rescue tractor. I've done a couple and here is what I do:
Drain the fuel tank and make sure it is clean. Pull off the sediment bowl and carb and clean both. Put cleaned carb into soak. I just go ahead and put kits in the carb and ignition system. Check all the wiring. If it's on six volts you gotta clean all the connections and make sure you have good wires AND the battery cables all the way to starter are HD (not hi def). Get all that done and check for fuel flow at the carb drain and check for spark. All this assuming it is not stuck. Stuck tractors are still out of my league. :-)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
