Posted by Armand Tatro on December 15, 2009 at 18:42:41 from (71.201.22.21):
In Reply to: Farmall 460 Gas posted by BenB on December 14, 2009 at 12:38:38:
With what you have told me you need to rig a short boom in your loader bucket, lift the front of that 460 and put it in your shop. Than disconnect the tie rods and with the front wheels of the tractor off floor check each spindle to see if it will turn. At this time the steering gear box will be disconnected from the front wheels and if the gear box is ok the steering wheel should turn. Also if the the steering shaft has any movement the bushings should be ok. Also down where the steel hyd. lines enter the back of the steering gearbox is a splined connection. The steering shaft needs to telescope at this coupling.Your problem will be at any one or more or all of these points. If you don't have a service manual you need to get a I&T service manual or I.H. shop manuals as all these points in the steering linkage will be explained and have pictures as will all other parts of the tractor. Armand
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
