The only parts available are O-rings, gaskets, and the garter spring. The valve body and spool are a select fit and must be kept together as a set. O-rings should correct external oil leaks. If the problem is not holding a cylinder in place under load there is not much you can do to the valve to cure it. If your cylinder is not leaking that problem is almost always caused by excess internal leakage between the spool and the housing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
