Re: Best way to loosen a stuck 460 gas
Posted by old on December 15, 2009 at 20:40:16 from (4.245.3.147):
In Reply to: Best way to loosen a stuck 460 gas posted by Andy in Ohio on December 15, 2009 at 19:58:51:
Brake cleaner will do nothing for it. Now most people know what I will say here and also know I get 99% of the tractors I have had with locked up engines and so far out of 20 plus only 2 or 3 have not freed up for me. I use ATF in every thing. Pull the plugs one at a time, fill the cylinders, put plugs back in to keep dirt etc. out. Let sit a week or so. Then pull all the plugs out and set a 12 volt battery in. Hit the starter button with short fast taps and you stand a good chance that it will spin over. STAND clear of the plug side of the engine because it is going to make a mess with the ATF shooting out of the cylinders. BTDT and an ATF shower is not fun but will not kill you either just teach you where not to be
