Posted by Pete7 on December 16, 2009 at 15:25:51 from (71.243.169.91):
Recently bought a Farmall 340 with a wide front axle (this is a row crop not the Utility) and started having trouble with the steering. You could turn the steering wheel but the tires would not turn unless the tractor was jacked up. With help from you guys I located a good used worm gear/shaft and matching wheel gear because I found the old ones were badly chipped and missing teeth. (tractor does have a loader on it) Thought that would solve the problem, right? Well, sort of, I can now turn the steering wheel and the tires turn ok, with the tractor jacked up. I don't feel any binding and it seems smooth thru the entire range, both running and not running while jacked up. But when I lower the tractor I can't turn the steering wheel. Doesn't matter if it's running or not, the steering wheel just won't turn more than a 1/4 turn or so. Shouldn't I be able to turn the steering wheel manually when the tractor isn't running? Do I have some thing binding the steering or is it a power steering issue? Pete
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
