Posted by pete 23 on December 16, 2009 at 16:33:52 from (173.87.0.174):
In Reply to: H pulley flange posted by SD Scooter on December 15, 2009 at 16:18:27:
On the H you do indeed need to remove water pump as the rear half of pulley must come off to get front pulley off, it is opposite of an M. After removing hub from rear of pump, take the bearings and seals out, drive the positioning pin out that is located in rear pulley flange, (might be hard to locate) then press pulley off. Measure distance before removing so as to put it back to same dimension. You can align original hole or just drill a new one upon reassembly.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
