Posted by JMOR on December 16, 2009 at 17:08:58 from (72.181.166.239):
In Reply to: Battery Tender II posted by The tractor vet on December 16, 2009 at 15:03:47:
Dellbertt said: (quoted from post at 19:03:47 12/16/09) I went to Kalamazoo today to check on the availability of a 6v battery tender.
Walmart had Schumacher 6v/12v for $20. (Never had good luck with Schumacher products)
Meijer (local chain) had Stanley 12v for $22 but it was 6-8amp.
Harbor Freight had a 12v/1.5amp for $9.99.
Question: If I buy the 12v Harbor Freight and add a 12v to 6v ballasts resister to charge a 6v battery will that mess up the automatic operation of the float charger and perhaps make it never shut off. Or will adding the resister have no affect on the charger operation?
Thanks,
Dell
A true battery tender/maintainer/float charger must see the actual battery voltage, so no it will not work correctly if you try to insert resistance between battery and charger. A battery can be charged like that, if you monitor specific gravity regularly during charging, but no auto shut off, etc. and you must be careful not to overcharge and as for the"battery tender/maintainer/float" function, that just plain won't work with 12v unit & 6v battery.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
