Re: 3rd wheel weight on a SM-TA
Posted by Tractored on December 16, 2009 at 18:44:33 from (75.134.220.220):
In Reply to: 3rd wheel weight on a SM-TA posted by RBTXS on December 14, 2009 at 17:30:25:
third party image
The inner and first outer weights are held on using two long bolts passing through the wheel. The other 5 weights use the remaining two holes and threaded rod going through all the weights (and wheel). I have found that this setup works well and is sufficient to hold the weight securely. I suppose that you could use threaded rod through the outer holes to add strength if you felt it necessary. Good luck!
