Posted by Wardner on December 16, 2009 at 19:07:20 from (4.154.244.222):
In Reply to: Re: hydraulics help posted by sluggo on December 16, 2009 at 17:39:04:
The loader had to have its own reservoir because the donor tractor had no factory hydraulics. Use that reservoir. Doing it this way completely divorces both hydraulic systems on the new tractor. That is not a bad thing.
I am afraid that I am missing something here because this solution seems so obvious and shouldn't be a source of confusion.
Provided that all four cylinders on the loader are double acting (two ports per cylinder) you could run both systems from the W-400 reservoir. Near the bottom left side of the W-400 reservoir is a drain plug. Put a Tee there and pipe both supply and return into it. Size the tee to be the same size as the supply port on front pump. Supply hose goes to pump. Return hose goes to reservoir port on fender valve.
That drain plug port is only 3/8" but that will be big enough because the only flow through the port will be the displacement volume of the chrome piston rods when they sre moving.
I made an error on a previous post. The W-400 CAN accomodate three valves. You could run the loader functions and the rear remote with only the IH hydraulics. That means you will have to buy a bunch of salvage parts.
When you get to the point where you want power steering, you will be going to the salvage yard. That might be a good time to price out the parts you will need to convert everything to IH if that is something you want to do later. IH power steering can't use the existing valves that are attached to the cast manifold above the reservoir. The PS valves look similar but are different.
I'd like to see a picture of the front mounted pump driveshaft and crankshaft coupling. I'm in the process of mounting a front pump on my W-400.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
