Re: 1456 steering loss
Posted by pete 23 on December 16, 2009 at 20:09:29 from (173.87.0.174):
In Reply to: 1456 steering loss posted by Paul Grage on December 16, 2009 at 19:26:56:
Don't overlook the o-ring on filter housing. Some of them don't fit very well and or the cover gets damaged. After that, most likely you are taking air in around the o-ring in split between rear and speed transmission. Main suction tube in rear end may have come loose also. Overfill at least 5 to 8 gals to see if it helps problem so as to cover that area with fluid. If all that fails, you start plugging holes and apply air pressure and listen for air leaks. What was reason for replacing pump to start with. Does main pump work ok. You can pull air in through them also if they are shot or suction tube seal to it is bad. With oil at normal level, if you pull filter, no oil should continue to run out of rear end, you may get a little out of main rear suction tube but I don't think so and if you do make sure it isn't coming from around the tube o-ring. You can plug that tube and over fill to see if it comes around the outside of tube. You will be able to tell if seal on rear pump suction tube is leaking also. These seals are very small and delicate, often times damaged when pump work is done. You will have to pull whole tear drop cover off to get a good look and work inside filter area.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
