Re: hooking up no. 30 power loader on h
Posted by rustyfarmall on December 17, 2009 at 05:53:09 from (209.152.78.140):
In Reply to: hooking up no. 30 power loader on h posted by mic h 560 on December 16, 2009 at 18:53:40:
gene bender said: (quoted from post at 02:11:44 12/17/09) The top hoses are for a two-way system and you only have a single way system. So un hook the top hoses and but breather caps in the ports. Now if you want to convert your system to two-way operation thats another deal but it can be done. How does the bucket work manual trip or does it have a cycl. If it has a cycl you will need to convert your systen to two-way. You need to post more info.
No. The top portion of those cylinders is a reservoir for hydraulic oil because the belly pump does not hold enough oil to fully extend the cylinders. Those cylinders are NOT 2-way cylinders. The top hoses need to be connected to the filler pipe for the belly pump. Installing a breather in the top portion is guaranteed to spray oil all over the tractor and you when the loader goes all the way to the top. Ask how I know.
