Re: inline hydraulic pressure reduction
Posted by charles todd on December 17, 2009 at 06:05:27 from (205.242.95.136):
In Reply to: inline hydraulic pressure reduction posted by Ron Snyder on December 17, 2009 at 04:50:20:
If you are really putting out 17 gpm and its rated for 11-12 gpm, then the blower should be kicking it. Volume at pressure is what makes it happen, displacement of oil. I think maybe your total system flow may be 17 gpm, but after steering and other sources of consumption and valving you may have half that. This is if you are using tractor hydraulics. If this is a PTO pump with an externat reservoir, I'd look for restrictions.
As for control, a motor spool valve or a motor speed control would do nicely. I do not know why you would want to install flow controls, because if its not fast enough its because of lack of flow not too much.
CT
