Re: Low Ash oil...Is there a lower priced oil out there ?
Posted by dhermesc on December 17, 2009 at 06:34:37 from (24.248.193.103):
In Reply to: Low Ash oil...Is there a lower priced oil out there ? posted by 706gas on December 16, 2009 at 17:00:46:
You could just use a synthetic all though not cheaper.
If I recall correctly Castrol GTX 10W30 was actually lower in sulfated ash than "IH" branded low ash oil. Most good engines oils out there are "low ash" but maybe not quite as low as the "Low Ash" IH brand. This site has a chart that shows the ash % on many well known brands. If I recall correctly IH "Low Ash" is .9%.
http://www.atis.net/oil_faq.html
http://www.nightrider.com/biketech/oilinfo1.htm
Then you have people that recommend diesel engine oil for gas engines which actually contain very high levels of sulfated ash (several times the level in "Low Ash" oil).
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
