Re: Farmalls and block heaters
Posted by Owen Aaland on December 17, 2009 at 15:49:50 from (65.165.246.148):
In Reply to: Farmalls and block heaters posted by ryanwheelock on December 11, 2009 at 05:48:25:
There are switches available with a side terminal that will replace the switch on the starter for the lever operated switches. For the remote mounted switches you could use a relay to supply the power to the coil while cranking.
