Re: inline hydraulic pressure reduction
Posted by PaulW_NJ on December 17, 2009 at 16:18:36 from (74.105.12.241):
In Reply to: Re: inline hydraulic pressure reduction posted by Ron Snyder on December 17, 2009 at 05:24:07:
I don't know much about hydraulics, but working in oil refineries for 25 years, if we had a pump that put out more flow than we needed, we simply installed a bypass, or kick-back loop. That is, installing a line from the pump discharge back to the low pressure side, with a needle valve in between. That way you could control whatever flow you wanted: the more you kicked-back, the lower the net output. Easier to correct too big a flow, than not enough.
Maybe you could try that . . . .
