You can swap all those tranny gears around except for the constant meah gear. There is only one of those from SMTA to 660 so there is no point in changing that. What you have to bear in mind is that all the gears have the same pitch (except constant mesh gear). This means that any tranny gear set has to add up to 73 teeth. D Slater has already told you about the bearings and their retainers.
Go to caseih.com and print out the transmission internals for 560 and either SMTA, 400, 450. Figure out what you want to do and write down the part numbers.
You want to go faster. I did just the opposite on a SMTA to go slower. I used 560 differential gears and 560 first gear. Speed in first gear is about .75 mph vs 1.5 mph stock using the TA. I probably have all the gears you need to go faster in all gears. The jump in second and fifth won't be as large (in percentage) as the others.
Click the link below for a thread on gear ratios and speeds.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
