Re: Wide Front M
Posted by Andy in Beloit on December 18, 2009 at 00:21:23 from (68.114.219.44):
In Reply to: Wide Front M posted by The JD Workmen on December 17, 2009 at 18:15:32:
Early w.f.s had the tie rod in back but, later ones were in front. The way easyest to tell is if the part under the bolster is a casting its a IH, if fabricated (welded plates) its after market. You can check the photos for examples.
