Re: Cracked block C-113
Posted by M Diesel on December 18, 2009 at 12:48:59 from (12.24.61.12):
In Reply to: Cracked block C-113 posted by Dalex on December 17, 2009 at 11:41:09:
gene bender said: (quoted from post at 06:04:35 12/18/09) I have used fiberglass,jb weld but i like the rubber cement they use to fasren the windshields in place best. Grind a small v then apply when wet you can use a stiff brush to make it look rough. Its not uncommon for those blocks to crack there and with a small crack like yours not hard to fix. I have welded and ground smooth but the rubber cement sure is faster and much eaiier.
Are you talking about the black sticky stuff, butyl rubber?
