Re: 6 volt/12 volt? - NOT How do I convert to 12 v
Posted by Pete7 on December 18, 2009 at 17:28:16 from (71.243.169.91):
In Reply to: 6 volt/12 volt? - NOT posted by sflem849 on December 18, 2009 at 15:15:38:
Hi... I'm not sure I'm following you very well but, I think you saying you have a 12 volt battery and you are measuring 7 volts at the battery?
If you got 6 volt generator 4 years ago, I would think the battery would have run down long ago. Seems more likely you have a bad regulator, generator or bad cells in the battery. Since you charged the battery with a battery charger and you are only seeing 7 volts at the battery, I'd get the battery tested first.
Pete
