Your points rubbing block needs to have one of the cam lobes directly under the rubbing block of your points. That's where and when you set the .020" point gap if you have a distributor.
You need to see if battery voltage is getting to the coil with the ignition switch on. Should have voltage on both small terminals with the points open. You need to use a volt meter set on DC volts or a test lite. If you have voltage on both terminals clean the points with some 320 wet or dry. Then pull one of your plug wires and have someone make an attempt to start the engine with the ignition swtich on and see if there's fire to your plug. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
