Posted by Allan In NE on December 19, 2009 at 06:16:08 from (148.66.88.254):
In Reply to: 52 H posted by deano4863 on December 18, 2009 at 20:09:07:
The best stuff I've ever used is the Top End Engine Cleaner from GM. Saved lots and lots of engines with that mixture.
The rings are 'probably' gobbed up with carbon, rust and crap. Soak it for a couple of days per directions on the can and then work the livin' snot out of 'er for a week.
If this doesn't cure it, ya need an overhaul and you've found out why it was parked to begin with. :>)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
