Re: Battery Cables
Posted by Scot in pa on December 19, 2009 at 06:16:22 from (68.28.105.230):
In Reply to: Re: Battery Cables posted by Bernie Steffen on December 17, 2009 at 17:59:26:
I got new clear battery cable at autozone or advance auto, and ran my ground up to a starter mounting bolt. I need to get the crimpid ends soldered and heat shrink over them, but it's been working good for 3 or 4 years now. I also use the marine grade dual-wall heat shrink. The inner layer is glue which melts into the connection and seals it. You can bury it in the ground and water won't seep in.
