Re: Super A - Problems...not starting.
Posted by Dellbertt on December 19, 2009 at 08:41:41 from (209.172.22.133):
In Reply to: Super A - Problems...not starting. posted by Brian Luton on December 18, 2009 at 12:35:18:
Air, Fuel, Compression, Spark. It should run.
Here's some things I would try:
Make sure no moisture or crack in Dist Cap.
Disconnect air intake hose from carb.
See if points are dirty or stuck.
Turn rotor to see if good arc/snap when points open.
Hold plug wire about 1/4" from plug and see it you get arc.
Warm up plugs over night and see if it will start.
Pull it in High gear and see what happens.
It sounds like it is cold, bring the whole tractor into the kitchen overnight to warm up.
Dell
This post was edited by Dellbertt at 08:43:44 12/19/09.
