Posted by Janicholson on December 19, 2009 at 09:20:02 from (199.17.6.222):
In Reply to: Farmall ampmeter posted by JayinNY on December 19, 2009 at 08:38:22:
I'll ad to Rusty and john's Info: If the battery appears to be Positive ground, ie, the positive terminal is actually connected to ground, then I would check the actual polarity of the battery. Use a good volt meter with the leads in the correct holes, and make sure positive is positive. Batteries can be charged backwards if they are really dead. If it is, and it is working OK charged backwards, I would remark the battery so it is really clear it is wrong, but OK. Then I would either turn the battery around and repolarize the gen to make it POS ground (amp meter reads correctly) or I would leave it alone and use it until it needs a new battery (assumes no others would be messing with it. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
