Re: 6v - 12v Charger question for you all?
Posted by sflem849 on December 19, 2009 at 10:31:53 from (66.254.196.101):
In Reply to: 6v - 12v Charger question for you all? posted by John Athey on December 19, 2009 at 10:21:37:
Are the batteries hooked in series or parallel? I know John Deere was big on hooking two six volts up together to make them 12 volts. Cat also did it with two 12 volt batteries. Are your positives hooked together or is one positive to the opposite batteries neg post? If the later is true they are hooked in series. This would mean you are running a 12 volt system and you should be charging/starting with 12 volts.
With all that said, you can cheat and use 12 volts to turn a 6 volt starter. You can't over crank it or you will burn up the starter in a hurry.
