Re: Farmall ampmeter
Posted by ScottyHOMEy on December 19, 2009 at 14:02:39 from (71.241.215.22):
In Reply to: Re: Farmall ampmeter posted by GordoSD on December 19, 2009 at 12:11:02:
Good thought, too, Gordo about the discharge. If he's running on a magneto with the lights off, he wouldn't show any draw after starting. So all I'd add, if he does have a magneto is to check which way the needle moves when he turns the lights on, with the tractor off.
As for the possibility of a short draing things smoeplace, I'd also suggest noting the position of the needle with the battery disconnected and, after making sure everything (lights and ignition (if it is a factor) are off, and see if the needle changes position with the battery connected. If not, and no spark as the battery is hooked back up, then I'd start with turning on the ignition switch (if it has a battery ignition) to see how far the needle deflects then. A little would be consistent if the points are closed, but it would show more if any short were along the primary feed to the coil. Just something in addition to the not-charging possibilities.
