Re: 6 volt/12 volt? - NOT How do I convert to 12 v
Posted by mkirsch on December 19, 2009 at 14:46:40 from (67.240.251.254):
In Reply to: 6 volt/12 volt? - NOT "How do I convert to 12 v" posted by sflem849 on December 18, 2009 at 15:15:38:
I doubt it's the wrong VR or generator. You would've had problems a LONG time ago.
At 7 Volts, though, that battery is SHOT. 12V batteries are permanently and fatally damaged if they go under 10.0 Volts. It may last a while if you start and run the tractor every day, but not forever.
