Re: Busted Rear End Case
Posted by F-Dean on December 19, 2009 at 15:37:59 from (67.72.98.88):
In Reply to: Busted Rear End Case posted by CVA59 on December 19, 2009 at 12:42:21:
This is a common ptoblrm on a H and M. I cracked mine last summer when two bolts out of the differential rolled over to the right side when I burried the right wheel in mud.
If it does not leak, live with it. If it is leaking, try J-B Weld.
