Re: super mta decals
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Farmer Bob on April 26, 2000 at 21:14:09 from (207.227.187.10):
In Reply to: super mta decals posted by gary on April 26, 2000 at 18:30:37:
Gary, It depends on what type of decals you bought for the SMTA. If they are the Mylar type all you have to do is to remove the protective coating on the back of them, spray liquid windex (not the areosol type) on the tractor where the new decal is going and then place the decal into position. You can slide it on the windex until you have it perfect. Then start squeegeeing the decal from the center out to the edges to get all the excess windex and air bubbles out from under the decal. Then use a soft clean rag to wipe over the decal being careful not to move it. These decals will be permanently set in about 24 hours.
If you got the dealer style I think they have to be put in water in order for you to slide the decal off of the paper backing and then get it on the tractor without getting any wrinkles in it. Not impossible but labor intensive and tedeous work. Good luck and post a pic of the tractor when you finish if you can.//FB
Post A Followup
: Re: Re: super mta decals
