Re: farmall m,wheel locked
Posted by glennster on December 19, 2009 at 17:08:44 from (99.90.9.153):
In Reply to: Re: farmall m,wheel locked posted by jim from az on December 19, 2009 at 16:54:50:
left brake is pretty easy. the brake rod comes thru from the right side of the tractor. there is a linkage on the tin cover. a small shaft comes out of the tin cover. where the linkage hooks to it, there is a cross bolt. spray up with a little penetrating oil, then remove the bolt. spread the clamp a little with a wide blade screwdriver and wiggle the linkage off the shaft.take the woodruff key off the shaft too. then remove the bolts that hold the tin cover on. you may need to slide a putty knife between the tin cover and cast housing to break it loose a little, then it should come off. the right side cover you need to slide both brake pedal out some if i remember right.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
