Re: farmall m,wheel locked
Posted by Brownie 450 on December 19, 2009 at 17:59:57 from (66.43.241.141):
In Reply to: farmall m,wheel locked posted by jim from az on December 19, 2009 at 16:21:47:
Jack the left side of the tractor & take careful note when the weight is just coming off of the wheel if there is play in the axle going into the left casting. If lots of play, could be a bad bearing[inner or outer] that has locked. First check out the brake thing as already laid out above.--below.
