Re: Changing timing and Governor gears on 100
Posted by Janicholson on December 19, 2009 at 20:18:04 from (64.61.211.58):
In Reply to: Changing timing and Governor gears on 100 posted by Paul in Ontario on December 19, 2009 at 19:47:36:
If the pulley and cover are off, they are much easier to remove with a puller than the crank pulley, remove the cam drive bolt, and pull it off. A propane torch will help warm the hub if it is stubborn, (no oxy acetylene) JimN
