The hydraulic block on the tractor requires a 7/8"-14 "90 Duro" O-ring fitting.
The standard female coupler from the factory is pictured. If it have international stamped on the collar, it is a safeway adapter. This will accept safeway and pioneer style male couplers.
If you were able to remove the adapter from the female coupler, it is just a 7/8"-14 x 7/8"-14, 90-Duro O-Ring adapter.
I'm still unclear what you're trying to replace or why, so I'll cover both. You can get both the 90 Duro O-ring and the internal 70 duro O-ring inside the female coupler if either of those leak. If you need a new Female coupler CNH 374780R92 is the only one I've been able to find. You will need to use the 7/8"-14 x 7/8"-14, 90-Duro O-Ring adapter as the coupler is female thread. If you can't find the factory replacement, you can use a straight adapter 7/8 O-ring to pipe. These are expensive puppies, so I just replace them with OEM.
If you can't get them to mate, A NPT standard pipe (what ever your loader hose requires) to safeway/pioneer coupler will work, as pictured above.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
