Re: Cub with two snow blades attached(pics)
Posted by Daniel Robertson on December 20, 2009 at 06:08:13 from (67.162.93.46):
In Reply to: Re: Cub with two snow blades attached(pics) posted by Wardner on December 19, 2009 at 20:59:05:
third party image
third party image
No didn't break the rod to the front blade. Had two blades on the tractor for some time, but would have to chain up one blade when using the other. Two of the valves control the front blade up/down, and also angle. TC controls the center blade, no need for down pressure here. One of the other spool valves control the angle on the center blade. The 4th spool valve controls the fast hitch cyl. The rear weights are still mounted, I reversed the rear wheels to get a little wider stance for stability.
