Posted by Jim Becker on December 20, 2009 at 09:45:04 from (173.57.141.22):
In Reply to: exhaust lift posted by Joe Dowling on December 20, 2009 at 08:27:18:
Janicholson said: Control of depth and down pressure were "springy" and (opinion) that is the major performance issue.[/quote:81788146c1]
The usual setup on a pneumatic lift system, the lift was run to either a fully up or fully down position. Operating depth was set with manual levers. The same concept was used on hydraulic operated equipment on the H and M.
[quote:81788146c1="Janicholson"]The pressure was modest, and it had to be to avoid likking the engine.
When in good condition, the pressure valve put a pretty tight seal on the exhaust. If you left it closed after the cylinder hit the end of the stroke, it could stall the engine.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
